08-31-2018, 02:52 PM
Dual Master Contactors with Single Battery?
I have a dual alternator, one battery system.
I am using the VPX-PRO which has two internal electrically independent banks, which is great, but there are still a couple of single-point failure components upstream of the VPX... the master switch and the master (battery) contactor. I'm not too concerned about the master switch, but I am concerned about an inflight failure of the master contactor which would shut down the VPX. I have backup circuits for the alternators' field and Vsense wires. My question is, instead of creating an Essential Bus to power a few necessities, which adds complexity, why not just have two master contactors? Is this possible with one battery? Could I just wire two master contactors in parallel that "close" when the master switch is flipped on, and if one "opens" the other is there to keep the circuit energized?
If this is possible can someone guide me to a wiring schematic?
ASEL Commercial/Instrument
N707XP Reserved
RV-10 Empennage- Complete
Wings- 99%
Fuselage-99%
Firewall Forward- Complete
Now Wiring Avionics
08-31-2018, 08:19 PM
I have personally know of two contractor failures, mine being one of them. Mine failed on the ground. I dissected and found the failure mode to be pitted contacts. I have two batteries, two busses and two contractors. The main bus is a VPX, and the secondary is a fuse block. I replaced the main contractor with a Blue Seas L9012 contactor.
If I were to install 2 contactors I would use a single pole double throw (spdt) as the master switch. Parallel the two contactors and actuate each contactor with each pole of the switch. If one fails, just switch to the other one.
Simply paralleling the contactors would not allow you to recognize that one failed.
Bill Peyton
RV-10 - 1125 hrs
N37CP
First Flight Oct 2012
Aviation Partners, LLC
08-31-2018, 08:24 PM
Failure of the master contactor is unlikely. If it does fail, that failure will likely occur during startup, not during cruise. Even if the battery contactor does fail during cruise, the electrical system might continue to be powered by an alternator, depending on how the aircraft is wired. The voltage may be unstable without a battery connected.
Yes, it is possible to connect two battery contactors in parallel. Use a double pole master switch, one pole for each contactor. And yes, if one contactor fails, the other will still provide a current path. Each contactor should be tested independently annually, otherwise you will never know that one has failed.
Having two contactors is just as complex as having one contactor plus E-Bus. Two contactors are heavier than one. And two contactors are heavier than one contactor plus one E-Bus relay.
I am not necessarily recommending two contactors, just saying that it is feasible.
Joe Gores
RV-12 Flying
08-31-2018, 08:45 PM
Just another data point...
40+ years of flying light aircraft. Three master contactor failures, all of which resulted in a total electrical failure. Two in IFR conditions. All were in certified aircraft.
This failure mode is rare but it does happen.
Dru Fisher
RV-4 N100DF
Gloster Aerodrome, Sealy, TX 1XA7
ATP, CFII, A&P, I.A.
EAA Tech Counselor
EAA Flight Advisor
09-01-2018, 09:43 AM
Aaron,
Adding a second master switch and solenoid in parallel will address this one issue, but sorry to say the single master switch and solenoid are not, in my opinion, your main single point failure risks.
If you plan on a backup mode that has just one or the other alternators feeding your panel (no battery connected) I recommend you fully test this mode. Be well instrumented so you mitigate frying expensive avionics. A neighbor just fried a radio by inadvertently quick cycling the alternator switch with the engine and panel up. I only turn off the primary alternator to do a periodic test to make sure the standby alternator picks up. On my designs it is impossible to have an alternator feed any avionics without one or both batteries on line.
Carl
09-01-2018, 10:29 AM
I have a second identical contactor right next to my primary which serves my ground power plug (which has already saved my bacon once). Obviously not useful in the air, but on the ground (where most failures would occur). It can be swapped over in just a couple of minutes. The spare has already been cannibalized out on a road trip once to get a buddy home. At the 10 year point I?ll probably swap positions of the two to balance the wear and tear.
Myron Nelson
Mesa, AZ
RV-10 N24EV
KITPLANES Contributing Editor
09-02-2018, 09:19 AM
Originally Posted by Carl Froehlich
Aaron,
Carl
Thanks for the input Carl. I am using a VPX which supplies power to both voltage regulators to both B&C alternators. So, if my master contactor fails, I lose the VPX and both alternators so the above scenario you describe isn't possible in my setup unless I'm not understanding something.
Scenario:
Master contactor fails in flight causing both alternators to go down (actually using only one at a time), but both are now unavailable. Battery now offline too.
- Engine still running as I use magnetos
- Both EFIS (Dynon HDX) automatically switch to their BU batteries.
- EFIS(on BU batteries), powers GPS antennas, both ADAHRS, ARINC, AP Panel, and KNOB Panel.
- I lose GPS(including NAV Radio), ADSB, Trim motors, Com Radios, Audio Panel, Transponder, AP Servos, Pitot Heat.
- I now switch the alternator offline
- Switch to Master Two (second contactor) and "poof", main battery is back online
- Switch the alternator back online
- Continue flight to destination with FULL capability
I guess my thinking is, for the weight of an extra master contactor and a few inches of cable(I could use some aft CG in the 10), and with the VPX having two independent buses (one will get me on the ground if the other fails), then why not?
Unless I'm missing something, this seems like a pretty darn good plan.
Thank you so much for everyone's input, much appreciated!
N707XP Reserved
Wings- 99%
Fuselage-99%
Now Wiring Avionics
09-02-2018, 09:45 AM
Originally Posted by A-Ron
SNIP....
As most RV-10s need a battery mounted aft, when you add the second master contactor just modify for two PC-625 batteries instead of the whatever big one you are using. Run both batteries in parallel. Now you have a more robust setup and it solves your ?I lost the battery? problem? with no pilot action. The two PC-625s provide for a very good W&B (assuming you are using a standard engine and Hatzell BA prop).
I replace one PC-625 every three years, so no battery is more than six years old. This gives me some assurance of battery reserve (a design element). The pulled batteries go on to a second life in tractors and such. I never use any sort of ticket charger or ?battery minder?. For extended ground panel operation I use a real regulated power supply connected to each avionics buss.
But per my email, if you add the second battery the door is open for a far more fault tolerant power distribution than this if you want it.
Keep in mind there are other failure modes besides a master solenoid that can make a battery go away. I recall reading about a twin (two engines, two alternators) loosing all power when a high resistance contact melted the common bus tie. Single point failures go beyond specific components failing. For you, the second alternator protects against only one failure mode, the loss of the primary alternator.
Carl
09-03-2018, 09:30 AM
Carl
Thanks again Carl. I like your recommendation of using two batteries. Using this setup, would you use two master switches, both being "on" during normal operations? Or just one switch?
Also, above you mentioned an email. Did you send me one? Cant seem to locate any email from you. Thanks again.
N707XP Reserved
Wings- 99%
Fuselage-99%
Now Wiring Avionics
09-03-2018, 04:08 PM
carl,you don't think that the solenoid is the major single point failure concern. there is a post with 3 of these failures on one pilot. what do you know of that is likely to fail more than 3 times in a pilot's lifetime?
Bob Noffs
n. wi.
dakota hawk/jab 3300 built and flying. sold 6/18.getting serious about the 12. in the hangar now as of 10/15/19
RV-12 kit as of 9/13
