Old 08-28-2018, 09:13 AM
dmat dmat is offline
Default Vinyl Over Old Painted Graphics
Ok guys, I am thinking about sprucing up the old simple paint job on my RV with something newer. My current paint job is the 90's thin line on fuselage which then opens up to cover the vertical stab.
Has anyone done this before? I'm trying to come up with a simple design which I can keep the white which is still in decent shape but still giving it a new look.
Pics would be greatly appreciated.
D
RV6A: N6389-->N456RJ - Avionics Upgrade & Restoration COMPLETE & Flying
WTB RV4/8?- Looking for a 4 or 8 that needs some love and TLC. PM me if you have one!
Donations Paid- Thank you VAF!
Old 08-29-2018, 12:38 PM
vfrazier's Avatar
vfrazier vfrazier is offline
Vinyl will transfer any blemish beneath directly through. Do not kid yourself. It will not hide a thing. I'd even argue that it might make any blem seem magnified.
In other words, you'll still see any paint line. You'll have to block sand it smooth to avoid a potential unsightly disappointment.
Also, light colored vinyls aren't always 100% opaque. You might get some shadows showing through too, although it is less likely if you are using top quality vinyl.
One last thought, you want CAST vinyl, not calendered vinyl. The calendered vinyl will be much more apt to shrink and crack on aging. Ugh. You don't want that on your bird. Ask the shop if you're having it made somewhere, or simply buy a premium cast vinyl if you're a DIYer.
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
1-888-F1AIRCRAFT (1-888-312-4727)
www.flyboyaccessories.com
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
Old 08-30-2018, 06:31 PM
Turbo69bird Turbo69bird is offline
Couldn?t agree with this post more. The vinyl is not something to use for cover up. Unless your doing the same graphic in a different color.
It will print through just about anything, dust a hair etc..
Proud owner of 925RV
Special Thanks to Fred Stucklen
While I'm not a builder if I happen to give advice , I will not be responsible for damage to equipment, your ego, parts, world wide power outages, spontaneously generated black holes, planetary disruptions, or personal injury that may result from the use of this advice.
