Old 08-27-2018, 07:02 AM
Floresb18 Floresb18 is offline
Default Empennage & Fuselage Connect
I ordered my fuselage a couple weeks back and that got me to wondering when would I connect the empennage and fuselage together? I have an electronic copy of the plans and did not find the point at which the two are joined. The plans just seem to show all of a sudden the two connected. Also I have not ordered the wings yet, those will come sometime around mid fuselage build.
Brandon Flores
N710LL Reserved
Dues Paid Apr 2019
buildanrv12.weebly.com
Empennage & Fuselage Complete, Wings In progress
Old 08-27-2018, 08:03 AM
John-G John-G is offline
Brandon -
Myself and others have held off on attaching the tail cone until late in the build. I actually brought the tail cone close to the fuselage and canted it at an angle so I could sit on a rolling stool while installing the auto pilot roll servo & wiring. Having the ability to stand and lean in a little to install the ADAHRS and associated wires along with pitot/static/AOA tubing the wiring made the task much easier than trying to do all that while crawling into the tail cone after mated to the fuselage ... at least for me.
Not sure how that will work with the new routing of the fuel system for the 912iS but I bet you could work around that easily enough.
Happy building,
John
www.dogaviation.com
RV-12 Wings, Empennage, Fuselage, Finishing, Avionics and Powerplant kits all completed
Now Flying!!
Donation paid until September 2021
Old 08-27-2018, 09:38 AM
DHeal DHeal is offline
IMHO, wait until the last possible convenient time to join the tail cone and fuselage together -- even at the hangar if that suits your space/transportation needs. I did as John above did -- I angled the two large pieces closely together to facilitate the final hooking-up of various components. Of course, the final connection and tensioning of the stabilator cables is accomplished after the tail cone and fuselage assembly are joined.
David Heal - Windsor, CA (near Santa Rosa)
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 940+ hours (as of September 2020)!
VAF donation through June 2021.
Old 08-27-2018, 09:39 AM
Thanks John, I figured it would be later in the build as someone told me that I would need access to the rear of the fuselage once the wings are built. I hadn't even thought of the AP servos..
Brandon Flores
N710LL Reserved
Dues Paid Apr 2019
Old 08-27-2018, 12:18 PM
You will want to install the the AP servos ... they are worth every penny. Can't speak for the Garmin install, but the Dynon AP integrated into the SkyView is robust and full featured. It is just pretty darn amazing ... especially if the AP and Knobs control panels are installed.
John
www.dogaviation.com
Now Flying!!
Old 08-27-2018, 08:19 PM
Oh I?m definitely getting the AP, I just meant I hadn?t thought yet about where they are installed
Brandon Flores
N710LL Reserved
Dues Paid Apr 2019
