Old 08-27-2018, 04:45 AM
Ron B. Ron B. is offline
Default Frequency flip / flop
I cannot remember what is required for a frequency flip/flop remote switch. I know you need it to go to ground but do I need a (NO) mom on/ off or a will a (NO) normal on off toggle work.
Thanks Ron
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 08-27-2018, 05:24 AM
vic syracuse vic syracuse is offline
Super Moderator
A momentary switch which it NO is needed. In other words, activating the switch will close it to ground.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 08-27-2018, 09:14 AM
Thanks Vic, that is what I was thinking. An ordinary on off switch will not work, must be momentary or you would have to switch it on and then off again and who knows what would happen if it was left in the on position.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
