Old 08-26-2018, 07:29 PM
smt6 smt6 is offline
Default ELT Transmits when power turned on
My ACK 406 transmits for 20 seconds each time the master is turned on, then stops. It is not the remote mount. The remote mount does its usual one beep and done. The ELT ON light is not on during the 20 seconds. I have tried toggling with the unit and even broke out the manual, to no avail. Any help? I?ll call them tomorrow, just looking for a Sunday evening fix
Old 08-26-2018, 10:50 PM
az_gila's Avatar
az_gila az_gila is offline
Question
I had a similar trouble when I re-used (the instruction said I could) the panel mount box from their 121.5 unit that I had replaced.
I never timed it to see if it went off after 20 seconds though...
Are you using the older 121.5 panel unit?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 08-27-2018, 08:56 PM
Didn?t know there was a difference in panel units
Old 08-27-2018, 10:07 PM
az_gila's Avatar
Exclamation
Originally Posted by smt6 View Post
Didn’t know there was a difference in panel units
My mistake, it was a ACK-04 retrofit for the older 121.5 AmeriKing unit I was attempting to do.
Initially ACK claimed the same panel unit could be used, but I now see they have changed that recommendation.
http://ackavionics.wpengine.com/wp-c...conversion.pdf
It did set off the unit when plugged in though...
Gil Alexander
Old 08-27-2018, 10:33 PM
romaja romaja is online now
Had the same problem and it wasn?t the ELT. My transponder antenna was too close to ELT and was activating it. I ended up moving the ELT.
Jim
_________________
Jim
Rans S20 Raven Sold Built in 2016
ATP, CFI/II/MEI
