Originally Posted by mfleming
I just reviewed the wing rigging plan. The plans say this: "Then square the wing with the fuselage. This is done by measuring from corresponding points on the wing tips to a common centerline point of the aft fuselage"
I'm not sure how to equate the HS being square with a point on the firewall and the wing being square using a point on the aft fuselage, being that the firewall is off by ⅛"
Yes, you’re correct about the plans. My bad. It’s been a while since I rigged mine.
The comment I made about using the point on the firewall is due to the fact that the point furthest away from the HS should in theory yield a more accurate measurement because of the better angle.
Skylor
