Originally Posted by echozulu
Doesn't this change with the material thickness being riveted or does it not affect it that much?
For a given length rivet, the material thickness should vary only a little.
For the record, I used the 'fixed set lengths plus washers' method. As others said, you very quickly build up a chart of what's needed for various rivet lengths and sizes. Or, the ability to eye-ball it pretty close.
