Old 08-22-2018, 05:50 PM
birddog486 birddog486 is offline
Default engine dimensions-prop flange
I'd like to start fitting the cowl on the RV7 but I'm trying to hold off on purchasing an engine until I'm farther along.
Can I use any model 320 or 360 for this or are there differences in the mount and prop flange positions?
I'd like to find a case and crank but would I be better off with a complete engine so the mounts sag a little so I position the cowl low enough?
I'm planning on the 0-360M1B eventually
