Old 03-25-2007, 03:38 AM
AntiGravity's Avatar
AntiGravity AntiGravity is offline
Question Polishing grove airfoil gear legs?
I seem to recall reading a post saying that the aluminium used in the Grove gear legs was of a type more susceptible to corrosion than 'normal'. Having received my beautiful legs I think it would be a real shame to paint them. I wondering about having them polished at the local metal polishers where I got parts for my motorcycles done, and then perhaps a couple of coats of clear lacquer to protect them and keep them looking nice?
Anyone have any comments? Yes? No? Be careful of...? etc, etc, etc.
Jeff Preou
Hamilton, New Zealand
STATUS: not building anything at all... yet ...
http://www.preou.com
http://www.kitlog.com/users/index.php?user=jpreou
Old 03-25-2007, 05:21 AM
Rick6a's Avatar
Rick6a Rick6a is offline
Originally Posted by AntiGravity
I seem to recall reading a post saying that the aluminium used in the Grove gear legs was of a type more susceptible to corrosion than 'normal'. .....Anyone have any comments? Yes? No? Be careful of...? etc, etc, etc.Thanks,
Jeff,
Do a Google search. That high strength comes at a price. Most data sheets I've reviewed seem to indicate that because of the many metals including magnesium, copper, and zinc in 7075 aluminum, the alloy is more susceptable to corrosion. That doesn't necessarily mean it will corrode if properly maintained and that includes polishing. Just as a test, I started to polish a gear leg using Nuvite Grade C. Within a very short time it became obvious that the Nuvite will quickly remove the fine file marks from the manufacturing process and the aluminum has the capacity to take on a high luster. Since I had no real way of securing the airfoil shaped gear so that I could continue to polish, I decided to wait until the gear legs are permanently mounted when I can then more aggressively apply force on the buffing tools. I will Akzo prime those areas of the gear that will be in contact with other parts of the airframe, hidden from view. Between the primer and the polishing, I personally don't consider corrosion to be much of a concern.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 03-25-2007, 07:10 AM
DanH's Avatar
DanH DanH is offline
I'm with Jeff; I'd like to polish but worry about corrosion.
Here's the Grove page on the subject:
http://www.groveaircraft.com/landing_gear_finishes.html
....which doesn't encourage polished 7075.
Dan Horton
RV-8 SS
Barrett IO-390
Old 03-25-2007, 09:55 AM
N62XS N62XS is offline
Default Chrome Paint
Buy a quart of the chrome paint that looks like polished, coat with epoxy primer prior to painting and you have the same effect with less maintenance.
IHN,
2020 Dues Paid
Robby Knox
THEM: Why do you always carry a knife?
ME: I can't open a bag of chips with my Glock!
Old 03-25-2007, 01:24 PM
Default Chrome paint
Oooh, good idea. I think I saw a post a while ago about these kind of paints. I must search it out. Thanks for that reminder.
Jeff Preou
Old 03-26-2007, 08:18 AM
phil9diesel phil9diesel is offline
Yes comment: Go do it. Buff them shiny and finish with aluminum wool. Paint them with clear stuff and strip it and recoat every few years. I'm going to be priming inside with varnish mixed with enamel hardener, and rivet wet. It will look sort of like your legs, I mean gear legs.
Old 03-26-2007, 08:29 AM
Baja_Traveler Baja_Traveler is offline
We had a Tailwind fly into our EAA meeting this month with custom made, polished grove gear. They sure looked beautiful - Never thought to ask how he finished them...
Kai Schumann
RV-8 Dreamer
Daily Lurker
VAF # 676
