Old 08-17-2018, 02:17 PM
AviatorJ AviatorJ is offline
Default Fuselage to Wingtip Measurement
My wings are in the hangar but I'm going ahead and starting to run my light wires. I want to leave enough wire from the fuselage exit to run it down the wing later. I was thinking the wings all together were about 15' (From when I moved them in a box truck). Does that sound right? If so I'll leave 16' of wire coiled up outside the fuselage.
Justin
RV-10, N10JW
First Flight 2/14/2019
http://operationrv10.blogspot.com/
Old 08-17-2018, 02:34 PM
1001001's Avatar
1001001 1001001 is offline
My wing measures 12' 5" from spar root to edge. Wing tips are about 18" at the middle.
Old 08-17-2018, 02:36 PM
Okay thanks, I'll do 15' runs.
Justin
RV-10, N10JW
Old 08-17-2018, 02:38 PM
1001001's Avatar
Just note that the 12' 5" doesn't include the tip, I may not have been clear there.
Old 08-17-2018, 02:59 PM
az_gila's Avatar
az_gila az_gila is offline
Exclamation
I found all of my calculations (err... guesses) for wire length needed based on drawings usually came up short.
Add 10 % if you think you are accurate or 15-20 % otherwise.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
