Old 03-24-2007, 11:48 AM
pierre smith's Avatar
Default Efis for back seater?
A friend is mounting a Dynon 180 in his -4 and thinks he can buy a cheap DVD monitor, like the ones in cars, and duplicate his D180 flight display for the backseater.
Have any of you guys considered this? Can it even work?
Curious....
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 03-24-2007, 12:40 PM
osxuser's Avatar
osxuser osxuser is offline
Someone was doing this, I don't remember for sure who...
RV4 wing in Jig @ KPOC
RV7 emp built
Old 03-24-2007, 12:54 PM
n468ac's Avatar
n468ac n468ac is offline
Curious....
Nope ... this type of question was posted to the Dynon support, they don't support multi-monitors.
(This post by: Christopher Checca EAA Lifetime Member #799388)
Allen Checca (father)
Christopher Checca (son)
RV-6A - N468AC
ENGINE: Lycoming 180 HP O-360-A1A
PROPELLER: Senisentch 72FM859-1-85
WEIGHT: Empty Aircraft 1152 lbs
BASED: KC09 - Morris, IL.
Flying since June 6, 2005
N468AC Web Site
Old 03-24-2007, 01:07 PM
OldAndBold OldAndBold is offline
Default Nothing cheap will work...
Curious....
Can it be done? Sure.
Would it be easy? Probably not.
Would it be bright enough and strong enough? Probably not.
You dig into the internals of the Dynon unit and figure out where and how the video information get to the display and wire in "something" to copy it out to an interface unit you yourself would build. Then, that video gets sent back to the rear seat monitor "somehow". Keep in mind that opening up the Dynon unit to do all of this probably voids the warranty and may damage the unit and make it cosmetically damaged. So already you may be needing to buy a second unit from Dynon(!)
Seems to me (as one who has spent much of his professional career modifying avionics and military devices to do things they were never meant to do) that it would be easier and better just to get a second unit from Dynon.
Producing the flight display image is easy. Finding the hardware to display it on well and for not too much is hard. I was flying a DA40 last week with a Garmin 430 and was frustrated by how dim the display was in the sun - so even a high quality unit like Garmin has still not quite solved the problem.
But its fun to think about. Myself, I intend to go basic old fashioned steam gauges at first, then add electronic displays of my own concoction later on.
Cheers
John Babrick
(HS will maybe be done this weekend!!!)
Old 03-24-2007, 09:17 PM
mark manda's Avatar
mark manda mark manda is offline
Interesting though. I seem to recall the dynon tech responding about this question also.
other companies like GRT and BMA can provide second screens.
other questions that are similar are the DVD screens versus a GRT screen. Guys are wanting to put lip stick cameras on their Harmon Rockets and display the video picture on the second GRT screen. I think it CAN be done. for taxi purposes.
I'm planning on just putting an used old Garmin color 295 GPS in the backseat of my HR2 project for the GIB to play with.
Interesting thought probably wrong company as already mentioned.
Old 03-24-2007, 10:18 PM
gasman gasman is offline
Curious....
Just find a cheap used DYNON. Now that the GRT sport is out, there should.
be many of the original DYNONS on the used market.
Old 03-25-2007, 06:59 AM
lucky lucky is offline
Default sell your the dynon sytem and get a GRT sport?
Get the GRT 2 display setup (3 if you had more real estate) and put one of the displays in the back. The GRT displays are not deep so I know it could be installed in the back of my RV8 easily enough. I'd have to look in a 4 again but it would be tight.
Old 03-26-2007, 06:59 PM
prporter prporter is offline
Could you Velcro this behind the pilot's seat? They also have several programs that plug into your PDA that migh work.
http://www.pcflightsystems.com/
Old 03-27-2007, 06:27 PM
N402RH's Avatar
N402RH N402RH is offline
Default AF-3400MFD
How would this work?
Brian my 13 year old son has been bugging me for an EFIS in the rear seat of our RV-4 for months. Since I never did anything about it he took matters in his own hands one Saturday and here is what he come up with. He took the boards from one of our AF-3400 EFIS units and mounted them parallel with the screen. The ?Prototype? cover will be upgraded from cardstock to Aluminum in the finished product.
AF-3400MFD Ideal for rear seat display. Connect the AF-3400MFD to any AFS EFIS/Engine Monitor or Dynon EFIS and you have a complete second display in a thin package.
Features
SD Card for Data Logging (even from a Dynon)
2 1/4" Depth
4 Serial Ports
1 Ethernet Port
No Orders will be accepted until the first day of the Sun-n-Fun Airshow.
Sincerely,
Rob Hickman
Advanced Flight Systems
Old 03-27-2007, 06:53 PM
Cuanto dinero?
