Old 08-12-2018, 06:05 AM
RONSIM's Avatar
RONSIM RONSIM is offline
Default Vaccum Pump Adapter/Gear IO540 to O360
I have the vacuum pump adapter/gear from an IO540C4B5 that I would like to install on a friend's O360A1A so he can install the B&C standby alternator on his -7A------ is this the same part?
Thanks for the help,
Ron
RV-10 Co-built, maintained, flown (sold)
RV-8A Maintained and flown (Sold)
RV-6A Bought and Flying (N177RV), upgrades $$$
IO360, 180HP/CS, AFS 5600T, D10A, G650, G430, G327, ADS-B, VIZ385 AP
Very Happy Contributor
Comm, SMEL, CFII, A&P
Based at KCLW (Clearwater, FL)
Old 08-12-2018, 01:43 PM
airguy's Avatar
airguy airguy is offline
Ron
No - I had this problem when I was building my engine - your adapter will be about 1/8" too long for the B&C alternator. It apparently doesn't matter on the vacuum pump that would go on there, and sometimes you'll find those adapters mixed on engines for that reason, but it does matter for the B&C alternator. I had to get mine changed when I found out I had the 540 adapter on my 360.
See this, and next several pages for solution - http://websites.expercraft.com/airgu...y&log_id=70677
Old 08-12-2018, 02:11 PM
Jesse's Avatar
Jesse Jesse is offline
I may have the one you need. I?d be willing to trade.
Jesse Saint
Old 08-13-2018, 06:27 AM
RONSIM's Avatar
Default Sure enough, won't fit!
Based on Airguy's post (thank you), I tried the new alternator (40Amp B&C) against the IO540 adapter/gear --- bottoms out with about a 1/4" gap.
Jesse ----Thank you, I will contact you about the swap.
Ron
