Originally Posted by IowaRV9Dreamer
I can't find the torque setting for the AN924-4D nut that holds the bulkhead coupling on to the fuel tank end rib. I can find torque values for the nuts that hold the flared tubes to the coupling, but not the nut that hold the coupling to the bulkhead....
OK - I've figured out that it is a 7/16x20 thread, so the standard thread table calls for 450-500 in-lbs for a "standard" nut or 270-300 in-lbs for a "shear-type" nut. I wonder what kind of nut this is?
Thanks for any help,
Dave... my FAA AC 65-9 Mechanics Handbook gives 40 to 65 in-lbs for all alum. -4 fittings.
The wording used is - "Alum. Alloy Tubing, Bolt, Fitting or Nut"
So the nut gets the same torque as the flare fitting... makes sense if it's all aluminum.
Steel fittings get 135 -150 in-lbs
AC 43.13 gives 50 - 65 in-lbs... but talks specifically about AN-818 nuts only.... but gives the exact same 135 - 150 for steel...
Aim for 55 and you'll be OK....
gil in Tucson
