Old 08-03-2018, 06:22 PM
dtw_rv6 dtw_rv6 is offline
Default Direct manifold intake for horizontal fuel injection servo
Here is my initial attempt at an improved intake for my IO-360. Right now I have the very common snorkel.
This doesn't have a filter (yet). The intent is to glue the printed pieces into a solid unit, sand smooth, then build the actual part from fiberglass.
I'm printing the components now for test fit into the cowling. I'll modify the nose length so that I end up about 1/2" behind the aft blades of the propeller. I'll also need some sort of flex connection out near the cowling intersection, but I think that will be a field mod once I start cutting the cowl.
Loosely inspired by photographs of Dave Anders' intake - I don't have much info on what his looks like inside, so I've started here. Any thoughts? The taper is 10:1 to allow for pressure recovery just prior stuffing all of the air into the fuel servo. I wonder if a flow straightener would be beneficial..... I'll definitely need an alternate air source.
Old 08-03-2018, 08:20 PM
rv7charlie rv7charlie is offline
Have you seen the Bower intake?
http://www.ramairforhomebuilts.com/products.html
Old 08-04-2018, 04:58 AM
I'm hoping to make mine for a fraction of the cost. It's obviously similar to what I'm attempting.
Here is what has inspired me:
Don
Old 08-04-2018, 06:54 AM
DanH's Avatar
DanH DanH is offline
Good if filterless, but the concept constrains filter size, and cone filters are small on pleat area anyway. The result is filter loss.
Built this one early on. At 390 air volume, pressure drop was poor. Looked at larger cone filters, then rejected the whole concept.
Only the flat filters have pleats 7/8" to 1" deep. If cut from the frame and spread out, the media area is huge. The goal was to see how large a flat filter I could stuff in the available space. This is a K&N 33-2124.
Measured filter loss was less than the filterless drop published for a Bower intake, and it's always filtered....no worries.
Dan Horton
RV-8 SS
Barrett IO-390
Old 08-04-2018, 07:25 AM
BillL BillL is offline
Default Another data point.
I have the SJ MK-3 FAB with the K&N E-0995 cone filter. This filter flange gets cut down to limit the diameter. The alt air flow path is not as clean as Dans, and the filter diameter is a challenge for clearance, even with the SJ cowl. At 3G's the air box touches my cowl.
The pressure drop has not been measured.
Bill
RV-7
Lord Kelvin:
Old 08-04-2018, 09:36 AM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Lovely design and work Dan. Always impressed with the stuff you do!
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
http://sdsefi.com/cpi2.htm
