Old 08-02-2018, 03:11 PM
Phenomflyer237 Phenomflyer237 is offline
Default Dyne oil sensor locations
Hi all we have a 0-320 D3G engine. I am seeing mixed answers on where to mount the oil temp sensor and the oil pressure sensor.
it seems the temp sensor can be threaded in directly to the location with a crush washer (does anyone know the size)
some suggest it goes up in a plug up near the front top of the engine. Others say near the filter
also on the oil pressure i believe than one needs a remote line to prevent damage to the sensor from vibration. which location does the pressure line go to?
Currently the builder used a T fitting off a remote line from the accessory/filter area
Lucas
