I agree with Bob, this is in the nice to have but in the not necessary category. Look out the window and count works very well. Also I only have a passing knowledge of how the different systems work, but know for sure it involves one or more of the following: wires, switches, circuits and connections. More = more chance for it to fail. Also you are adding expense and weight. Both not good. When your fancy flap control system fails to extend or retract you will not be happy and trouble shooting it will be a pain.
My simple system used the standard 3-position DPDT switch with (up)-off-down. The down position is momentary, so it requires the switch to be held for flap extension. Not a burden when it only takes about a 6 count from full up to full down. A short 3 count was good for about 1/2 flaps. There is little difference between 18 degrees and 22 degrees to the airplane. Precession flap position is not necessary; UP-(approx)1/2- DOWN is all you need.
To retract, the flap switch locks into the up position so holding it is not required. A limit switch kept the motor from running if I forgot to place the switch into the off position. This lock feature is handy for after landing and go-around. Also, unlike an underpowered C-150 with massive slotted flaps, any RV can retract the flaps in one motion due to the power, acceleration and how small a difference the flaps make to the stall speed (3 mph). No need to milk it.
Cheers George
