Bearings
David,
Just confirming that Gil is correct. The upper rod end bearings are the standard looking ones and attach into the flap actuators in the cockpit. The lower rod end bearings do have a stud sticking out to the side. The lower stud bearings don't care if they are left or right, just mount them with the stud outboard to attach to the inner mounting point on the flap. CM-4M on top, CM-4S on the bottom.
RV-8, Flying
Previous airplanes: Corby Starlet, Citabria, Cessna 140, Vari-Viggen, RV-3, RV-4
RV grin every flight
"Sure is nice to have smart friends"
2018 dues paid
