Old 07-27-2018, 11:00 PM
lndwarrior lndwarrior is offline
Default Interpret my spark plugs
Engine: Lycoming O-235-C1 (low compression)
TSMO: 270 hours
Hours on plugs: 130
Fuel; Half time on 100 LL / half time on autogas
Oil: Aeroshell 100 Plus
Additive: Camguard
All plugs quite similar in appearance. Some slight carbon buildup up on #3 and #4 bottom. The rest have a coating of whitish/yellowish crusty material. All cleaned off easily with a small portable spark plug cleaner.
This service was part of conditional inspection.
Engine seemed to run fine. Never a problem with the engine and high temps.
I'm wondering what the white/yellowish crusty stuff indicates?
https://photos.app.goo.gl/kNGegsyMTtFbaE2k8
https://photos.app.goo.gl/xFmKQKZL9fswH9Ua9
TIA
Gary
Old 07-27-2018, 11:29 PM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
Normal deposits from TEL and Bromine scavenging.
More important, make sure you gap them ( 0.016" - 0.018") and check their resistance, and they should be under 5000 ohms.
They may well be near end of life.
______________________________
David Brown
DYNON Authorised Dealer and Installer
The two best investments you can make, by any financial test, an EMS and APS!
