Amateur-built aircraft are not "approved" in the operating limitations. The statement in the op lims puts the monkey on the back of the operator. The aircraft is approved for night flight if it complies with part 91.205(c).
If you have only 120? coverage with the wingtip unit, then you will need a tail light/strobe.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
