Dynon does not recommend the use of stainless, according to the install manual. They also, somewhere in there, warn of using a magnet to test for ferrous metal as it will then possibly magnetize said metal. Certainly okay, in this case, if you don't use the screw that you test.
Brass, as you plan to use, is what they recommend but nylon sounds like a good alternative. Try running the nut onto steel screw before installing on the brass screw.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
