Old 07-26-2018, 04:37 AM
maus92 maus92 is offline
Default RPM Gauge marking O-360-A1A FP
I had to delete my RPM gauge from my G3X system, and re-enable. Lost the RPM arcs / marks in the process. I'm wondering what others are using. I was using 2700 redline, green arc up to 2450, yellow arc between 2450 and 2700. Not sure if this is optimum...
CA
2000 RV-8A | O-360, SDS CPI, FP, G3X Touch, VP-X, EarthX | Eastern Shore | KESN
Old 07-26-2018, 04:28 PM
jrs14855 jrs14855 is offline
Default Markings
For a certified Sensenich metal FP there is a yellow arc below 2350. IIRC 2150 to 2350. No reason for the upper yellow arc. The parallel valve engines really like 3300 r/m for acro.
