I’m installing a YIO-320-D1A into a rv9a that had a propstrike (not mine). The engine was sent to Lycoming for repair and received it back as seen except I placed the fitting in the typical place to pick up the oil pressure with the restrictor 45’ fitting. To the question, I see a 45’ fitting just to the left and above of the right mag. Is this a possible area to pick up oil pressure as well?
Bill
