Go Back   VAF Forums > Main > Reviews
Old 07-18-2018, 04:24 PM
Av8torTom's Avatar
Default Wire Crimper
I just got this YQK-70 10 ton hydraulic wire terminal crimper from Amazon for $37.
Works VERY well with dies from 12 to 2/0 AWG. Only draw-back is that the dies are marked in mm2, but you can easily find conversion charts to AWG on line.
Don't see how you can beat it for the buck.
N677AT reserved
Superior XP O-320, 160HP
Old 07-18-2018, 07:22 PM
JonJay's Avatar
JonJay JonJay is offline
Those are some rough looking dies, but if they get the job done, that's all that matters.
For what it is worth, I only use seamless barrel terminals. They cost a bit more and it probably doesn't matter for a ground strap, but.....
( don't you know if you post a pic on VAF, you get unintended side chatter...sorry)
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 07-18-2018, 08:54 PM
Av8torTom's Avatar
The dies are actually quite nice - I think the light reflecting off them makes them look rough. I crimped some 2 gauge wire as well, and it looks bomb proof. Thanks for the tip on the seamless terminals. I had thought I ordered those but apparently I didn?t.
N677AT reserved
