Originally Posted by Jkkinz
When I built my tanks, I went to the local office supply store and picked up a postal scale. Set it for grams and was able to get a very accurate 10:1 ratio.Jim Kinsey
7A fuselage
Ditto. A postal scale is what I use and is very accurate. That precision requires making up (on my scale) a batch of 11 grams of proseal at a time...perfect for most jobs. On occasion, I've only needed 2 or 3 grams to do a small job. Proseal is in actuality, relatively forgiving of an imprecise mixing ratio. I'm certainly not recommending anyone do this, but when I need a small amount, I simply "eyeball" what I think is a 10-1 ratio in a paper cup and punt. With a practiced eye, you can tell if you are close...too dark and its got too much part B, too light...not enough. I still have some proseal dated year 2000 and though decidedly stiff to mix, it works, but I just use it for non critical tasks such as caulking holes, optional fay sealing, etc. It even fixed the one weeping rivet I had, stuffed around the rivet from the outside in........and that was several months ago. In my experience, I have never seen cured proseal mechanically fail. I really like the new Flamemaster Van's recommends, it seems significantly "creamier" and mixes easily without wearing out your arm.
