Shiny side towards heat source and shadowing the desired area to be blocked. The rest is for aesthetics.
If the shield is in contact with the item to be blocked, then an insulating barrier would be in order as the shield will still have an elevated temperature from the radiating source but at a much lower temperature. But wont it radiate heat too? Yes, but the lower temperature will radiate much much less than the original source.
Bill
RV-7
Lord Kelvin:
