Old 07-15-2018, 07:42 PM
Drifteral Drifteral is offline
Default Prop flange bushings.
Have a lycoming O-320-A1A with 3/8 flange bushings. Need to convert it over to 7/16 bushings but i'm having trouble finding the part #'s. Reason is my prop has 7/16 holes.
If i'm reading the parts book right I need the following lycoming part numbers:
1 ea 72065
3 ea 72063
2 ea 72064
If this is correct my questions are:
1. Why 3 different part #'s?
2. Where to get them reasonably priced?
Al
Old 07-15-2018, 10:53 PM
az_gila's Avatar
az_gila az_gila is offline
Thumbs up
This may be a better reference than the parts manual -
https://www.lycoming.com/sites/defau...20Location.pdf
The three numbers are for different lengths and one of them is the "index" bushing and fits into a slightly larger hole in the crank flange.
Try your local engine rebuilders for used parts - they usually salvage them from scrapped cracks.
Check the thickness of the prop flange, it does affect the part numbers, but it's covered in the SI linked above.
Check the bushings you are removing to see if there is a Pxx number on them. This would indicate an oversize drive bushing.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 07-16-2018, 09:33 AM
Thanks Gil,
That help a lot!
