07-13-2018, 05:28 PM
High Fuel Pressure, Carb Eng, Idle Only
Should I be worried? Is this a sign of a failing fuel pump? Lycoming has a max fuel pressure of 8 psi for carb engine. My EFIS alarm goes of at idle because fuel pressure briefly raises to 8.3 psi. This is without the electric pump on. Has anyone else had this issue. This has happened several time, it is only momentary and only happens at low rpms. Hmmmmm
Larry Mcc
Retired
RV-8, sold
RV-9A, flying 6/18/2018
07-14-2018, 07:20 AM
ground issue?
Do you think you have an intermittent ground somewhere? I would tend to think not because it doesn't happen while at cruise power.
07-15-2018, 12:57 PM
Larry, i am very curious about this. Please post an update as to what you found to be the culprit.
07-15-2018, 01:43 PM
I will do some more testing tomorrow. Also of note, at hi cruise 2400 rpm the fuel pressure is 7.2psi. I think it should be no higher than 3psi. Hmmmmm.
Larry Mcc
Retired
RV-8, sold
07-15-2018, 02:33 PM
Happened to me, and also caused carb to overflow, creating a dangerous situation. Installed a new pump and also rebuilt the carb and all is perfect again.
Chris
Chris Johnson
RV-9A - Done(ish) 4/5/16! Flying 4/7/16
07-18-2018, 07:53 AM
I have eliminated the gauge and pressure sender, as the elec. boost pump reads 4.5 psi.
Checked and cleaned the gascolater and carb finger screen, no debris or blockage. Checked the archive and this seem to happen on engines that have set for over a year. Mine had set for 10 years. Lycoming suggest replacing fuel pump every 10 years. So i guess i will bite the bullet and purchase a overhauled pump. Will post the results.
Larry Mcc
Retired
RV-8, sold
08-16-2018, 03:09 PM
This recently happened to me. But I'd been flying the plane regularly. But the pump was well past the suggested 10 year replacement interval. I have been getting oil droplets accumulating on the heads of the lower bolt heads. Fired it up the other day and the pressure went straight to 8-9 psi at idle...high pressure remained at 2000 rpm, so did not fly it.
I've ordered a new pump & gauge and should have them installed next week.
Seems a lot of these accessories start failing after 15 years in service. To be expected, I suppose.
Kind regards,
Tom
RV-8 N269CP
O-360-A1A w/Hartzell CS prop on 100LL
Slick-IC+PMag ignitions
Steam gauges
EI UBG-16, FP-5, & MUX-8A datalogger
Garmin Aera 660
TruTrak ADI Pilot II (GPS coupled)
Garmin GDL39 3D ADSB-In
uAvionix Tailbeacon ADSB-Out
Infinity grip w/Matronics trim speed control
Reiff preheater system
TCW oil cooler air damper w/servo drive
AntiSplat oil mist separator
Mountain High O2D1 O2 system
