Old 07-09-2018, 06:32 PM
goanddo goanddo is offline
Default Center brace attachement
I just want to say up front THANK YOU to people who generously share their knowledge. I really am very grateful.
The Center cabin brace is attached to the cabin top with four screws (MS24694S72) and four spacers made from aluminum tube (AT6-058X5/16).
Here is the part I am having trouble with, the head of the screw is almost the same diameter as the spacer which is the diameter of the hole.
Screw head Diameter .351
Spacer Diameter .312
Hole diameter 5/16 .312
How does this setup hold the brace securely? Surly, I am completely missing something? Can someone please set me straight?
Thank you! Thank you!
Ron
Old 07-09-2018, 06:51 PM
Electrogunner Electrogunner is offline
Default Hardware
Check the hardware call out again. I seem to remember the head of the bolt being a larger diameter. The spacer material is correct.
RV10 N620RV
IO540 C4B5
Whirlwind 375RV prop
Garmin G900X
First Flight 2/14/2019
Old 07-10-2018, 06:46 AM
Lynnb's Avatar
Lynnb Lynnb is offline
FYI, your pictures are not showing up.
RV-10 in Process
Old 07-10-2018, 08:01 AM
flion's Avatar
flion flion is offline
The screw head was slightly larger but I wasn't happy with the arrangement, so I chucked the spacers in a drill press and used a triangle file to make a couple of very shallow notches in the spacer and then roughed the remainder of the surface up. I then glued the spacers in, with a generous amount of epoxy and flox in the space inside the cabin top in that area. There was nothing in the instructions about gluing them in but the company often does not give explicit instructions about common procedures.
EAA Technical Counselor #5357
Old 07-10-2018, 08:59 AM
ppilotmike's Avatar
Default I am at this point also..
..Has anybody used washers or something under the heads of the screws? I seem to recall seeing an airplane with tinnerman (?sp) washers under the heads to better support the loads..
Mike Rettig
VAF Dues Current
Old 07-10-2018, 01:34 PM
IMHO the brace is mostly for roll over protection, when the screw will be mostly in shear and maybe compression. Forces on the small lip of the screw head should be small. I think Vans? engineering gave some thought to this design.
Old 07-10-2018, 02:57 PM
lr172 lr172 is offline
You install the al spacer flush or a bit proud of the f/g and then countersink. The 100* countersink will transition from the fiberglass and into the spacer. That countersink angle will allow the screw head to properly apply compression/tension on spacer once tightened. I wouldn't modify this, as it seems to work properly.
Larry
