Old 07-04-2018, 07:44 AM
Michaelpk3 Michaelpk3 is offline
Default Oil change after engine work
Removed cylinder #3 and had it overhauled. The engine has about 950 hours TT and that cyl had some oil blow by (always had a oily wet plug). I changed oil to mineral oil after repairs. My question is, how long should I run that oil before changing it? I did all the recommended break in procedures. Seems that it burns more oil now (although plug is dry) but I?m hoping that part of the break in. I?ve got 15 hours in the break in oil.
Also, is it worth doing oil analysis? Or will there be high metal content from the ring break in?
Michael Kalfsbeck
Michaelpk3@yahoo.com
N505AT RV-7A based in Sarasota, FL
Old 07-04-2018, 10:24 AM
Robin8er Robin8er is offline
I'm not an expert, but I know that oil consumption is normal during engine break in. I also know that you are not supposed to do oil analysis during the break in process because your numbers will be through the roof because the engine is still wearing in. I think I recall 10 hours being when you are supposed to change the oil after a break it, then normal intervals after that.
RV-8 N695RA flying
Working on an RV-4
Born to fly, forced to work
Old 07-04-2018, 11:18 AM
lr172 lr172 is offline
5-10 hours on the oil with a new or overhauled engine. I would probably not do it that early after replacing one cylinder if I had an oil filter. The debris load should not be that high.
Larry
Old 07-04-2018, 11:26 AM
ALagonia ALagonia is offline
I have always kept operating with mineral oil until I saw a noticed decrease in oil consumption. On our O-540 it took as much as 25 hours to see the drop in oil consumption.
Old 07-04-2018, 01:36 PM
Thanks guys! Just another reason I love this forum!
Michael Kalfsbeck
Old 07-04-2018, 02:05 PM
Originally Posted by Robin8er View Post
I'm not an expert, but I know that oil consumption is normal during engine break in. t.
This is generally not true, especially during the first hour or two. However, if you bought a new engine from Lycoming, you may not notice much consumption, as they do a short ?run-in? at the factory, so you?re not starting from scratch.
