Old 06-30-2018, 10:08 AM
jask jask is offline
Default Hot start angle valve
On a hot start after a 10 min turn, the engine emitted two, maybe three loud blams before it smoothed out. What caused that and how is it preventable?
Old 07-01-2018, 03:33 AM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
Most likely vapour lock in the lines.
Often after a hot start you will need to run the boost pump.
______________________________
David Brown
DYNON Authorised Dealer and Installer
The two best investments you can make, by any financial test, an EMS and APS!
