Old 06-28-2018, 02:44 PM
YellowJacket RV9 YellowJacket RV9 is offline
Default New FAA training rules
It looks like some nice changes may be coming to the rules - most specifically (for me, anyways) allowing time in Technically Advanced Aircraft (which many of our RV's may qualify as) to count towards a commercial license.
"In April, the FAA discontinued the requirement that commercial pilot and flight instructor candidates conduct their single-engine airplane practical test in a complex airplane, and the final rule published June 27 takes that a step further. As of Aug. 27, commercial pilot candidates can use "technically advanced airplanes" in lieu of, or in combination with, a complex or turbine-powered airplane to satisfy the 10 hours of required training in these airplanes. This is estimated to save trainees $2.8 million over five years."
"Generally speaking, aircraft equipped with an electronic primary flight display (PFD) and multifunction display (MFD), as well as a two-axis autopilot, would qualify as a TAA,"
Now to find a CFI and DPE who are RV-friendly. I feel like I could spend a lot more time getting comfortable with the commercial maneuvers in my own plane, as opposed to having to learn and do it in a 30 year-old Arrow.
Chris
Chris Johnson
RV-9A - Done(ish) 4/5/16! Flying 4/7/16
Old 06-28-2018, 03:11 PM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
Unfortunately I?m just a little far away, and haven?t done commercials maneuvers since forever.
Ed
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2020 dues slightly overpaid
Retired - "They used to pay me to be good, now I'm good for nothing."
Old 06-29-2018, 07:01 AM
RONSIM's Avatar
RONSIM RONSIM is offline
Default May be able to help
Chris -- if you cannot find a CFI willing to work with you in your airplane, maybe I can help. I do not want to take work away from someone who does the instruction for a living, so try to find a willing participant. We have several good instructors here, at KCLW, but I have never queried them on their aircraft preferences.
However, if you cannot find anyone, I would enjoy working with you in your airplane.
Ron Simonton, CFII
RV-10 Co-built, maintained, flown (sold)
RV-8A Maintained and flown (Sold)
RV-6A Bought and Flying (N177RV), upgrades $$$
IO360, 180HP/CS, AFS 5600T, D10A, G650, G430, G327, ADS-B, VIZ385 AP
Very Happy Contributor
Comm, SMEL, CFII, A&P
Based at KCLW (Clearwater, FL)
Old 06-29-2018, 10:45 PM
Turbo69bird Turbo69bird is offline
Chris
I know a guy in Stewart FL that might do it. pM me and I?ll give you his info.
Proud owner of 925RV
Special Thanks to Fred Stucklen
While I'm not a builder if I happen to give advice , I will not be responsible for damage to equipment, your ego, parts, world wide power outages, spontaneously generated black holes, planetary disruptions, or personal injury that may result from the use of this advice.
