Old 06-24-2018, 11:14 AM
Av8torTom's Avatar
Default Facet Fuel Pump
Started running the fuel line from the gascolator to the aux. fuel pump, and it looks like the male flare fitting on the pump is something I don't have a female nut for. Do I have to buy a special nut and ferrule?
N677AT reserved
Superior XP O-320, 160HP
Old 06-24-2018, 11:19 AM
rv7charlie rv7charlie is offline
Which Facet do you have? There are over a dozen different versions, but IIRC, the one Van sells has AN-6 fittings on both ends. If that's what you have, you just slide on the B nut & sleeve, flair the -6 tube, and connect to the pump.
Old 06-24-2018, 11:29 AM
Av8torTom's Avatar
Default Pump
I have the one that Vans sells 40108. Says it has a 37 deg 3/8" flare fitting, but I don't have anything that fits it. Seems like the threads are different.
N677AT reserved
Old 06-24-2018, 11:48 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
You need this nut - in size 6D alum -
https://www.aircraftspruce.com/catal...ages/an818.php
And this sleeve - again 6D in alum -
https://www.aircraftspruce.com/catal...ages/an819.php
These two parts will mate a 37 degree flare on the 3/8 alum fuel line in your kit to the pump fitting.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 06-24-2018, 01:22 PM
Av8torTom's Avatar
Thanks Gil!!!
N677AT reserved
Old 06-24-2018, 01:36 PM
Uh, that's what *I* said. :-)
This begs the question: What fits your gascolator? Those are standard AN-6 parts that Al linked.
Old 06-24-2018, 06:07 PM
Av8torTom's Avatar
The fuel pump does not appear to have a standard AN fitting. The gascolator does.
N677AT reserved
Old 06-24-2018, 07:15 PM
Can you link to a pic? This afternoon, I checked 40108 that I have in the hangar, and standard AN -6 tubing and fittings work fine on mine.
Old 06-24-2018, 10:27 PM
rvbuilder2002's Avatar
The Facet 40108 pump has fittings that are dimensionally the same as a flared AN -6 fitting.
Scott McDaniels
Hubbard, Oregon
Old 06-25-2018, 07:34 AM
Av8torTom's Avatar
Default Wrong fitting?
I?m using 3/8? tubing for this connection from the pump to the gascolator. The connection to the gascolator (bottom of image) is fine, but the same fitting won?t fit the pump (top of image). Maybe it?s the wrong size fitting?
N677AT reserved
