Old 06-23-2018, 08:31 PM
maus92 maus92 is offline
Default Broken exhaust hanger
Discovered during condition inspection. Has any ever had one of these break before? Any tips on ordering a new one? I believe this is a Vetterman system, but I don't see parts on their website (also called Friday and left a message - although it looks like they keep limited hours on Fridays (I wish I could do that.))
https://www.dropbox.com/s/qb172t5jb5..._0934.png?dl=0
CA
2000 RV-8A | O-360, SDS CPI, FP, G3X Touch, VP-X, EarthX | Eastern Shore | KESN
Old 06-23-2018, 08:34 PM
scard's Avatar
scard scard is offline
Yes, they have broken before. It is a simple piece of stainless tubing, easily fabricated in a few minutes after you source the tubing... from Vetterman Exhaust if you like .
Scott Card
CMW E-Lift
VAF Advertiser
Old 06-23-2018, 08:38 PM
Sam Buchanan's Avatar
been here awhile
RVers have been repairing exhaust hangars since....there were RV exhaust hangars.
Go to your local auto parts store and pick up a length of 3/8" steel brake line. A piece a couple of feet long will keep you stocked with exhaust hangers for many years to come. Gently flatten one end of a piece of brake line, drill the bolt hole, loosen the clamp on the rubber hose and replace your broken hanger. Keep a short piece of brake line in your flight kit for repairs when away from home.
Sam Buchanan
RV-6
Old 06-23-2018, 10:03 PM
Thanks everyone, another project!
CA
Old 06-24-2018, 09:20 AM
drill_and_buck's Avatar
drill_and_buck drill_and_buck is offline
Left unresolved, a broken hanger can cause bigger problems. A good reminder to give each pipe a wiggle test as part of your preflight procedures.
Mike Draper
RV-8 N468RV
First Flight 11/13/2011
TMX0360, Dual Pmags, CS
Old 06-24-2018, 10:07 AM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is offline
I had a recurring ploblem with these flattened steel tubes breaking off just like yours. I replaced them with solid aluminum rod. Never had another problem.
Carl
Old 06-24-2018, 11:26 AM
Aggie78 Aggie78 is offline
Default Replacement Hangers
After I discovered a couple of broken ones, I sourced new ones from the folks up at Vetterman, who have designed a thicker, more robust set.
Approximately 100 hours since I?ve replaced them all with the newer ones and no breakage so far. Looks like a good fix.
I check them every time I pull the cowls off...when it?s also a good time to hit all the exhaust pivot joints and unions with a healthy dose of Mouse Milk to keep them able to move as they are designed to do.
You will develop a list of items that you?ll check every time you un-cowl ?just to be certain? or after having had an issue inflight...
The exhaust system and components are a good candidate for this list...among others.
Rob Schroer
RV-7/N75WV
YIO-360-M1B
New Braunfels, Texas (KBAZ)
Old 06-24-2018, 12:55 PM
been here awhile
A couple of items I've learned after nearly twenty years of fiddlin' with exhaust hangers on the RV-6:
1) If you use steel tubing, the flattened end should be made with a gradual swage, not an abrupt swage as will result if you just slam the vice jaws down on it. A small radius swage is much more likely to break.
2) My earliest set of hangers used not only the flattened ends but also a bend in the flattened portion. That is certainly a recipe for failure. After repositioning clamps to eliminate any bends reliability went up considerably.
3) The aluminum/steel rod instead of steel tubing is a good solution if it fits the particular installation.
Sam Buchanan
RV-6
Old 06-24-2018, 01:05 PM
Agree 100%.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 06-24-2018, 01:53 PM
erich weaver's Avatar
If you use steel tubing, the flattened end should be made with a gradual swage, not an abrupt swage as will result if you just slam the vice jaws down on it. A small radius swage is much more likely to break..
What is your recommended technique for producing a gradual swage Sam?
Erich
