Old 06-23-2018, 06:22 PM
Charles in SC Charles in SC is offline
Default ACS ignition switch question
I have an Aircraft Spruce ignition switch. It came with a small wire with a diode made in it with instructions about installing it between a ground and the switch terminal on the start relay. What is the purpose of this wire and diode?
Thanks in advance!
RV 7
Old 06-23-2018, 09:28 PM
johnbright's Avatar
johnbright johnbright is offline
When the solenoid coil field collapses it generates a reverse voltage (flyback) that would arc across the switch contacts as they open and damage them. The diode shorts this voltage and turns it to heat within the diode's resistance rather thah spark heat at the switch contacts. It's a flyback suppression diode. Diode's cathode to positive terminal of solenoid.
John Bright, RV-6A 25088, N1921R reserved, at FWF
O-360, 8.5:1, vert sump, dual SDSEFI EM-5-F
Schematic and other electrical related files
Instrument panel CAD jpg images
Construction Photos
Newport News, Va
Old 06-23-2018, 09:42 PM
The diode only goes on one way - the band end to the switch terminal.
Old 06-24-2018, 05:15 AM
snopercod's Avatar
When the service bulletin came out and I changed my ignition switch, I took the old one apart. You can see a little arcing on the leftmost contact. The diode will prevent that.
(2020 dues paid)
Old 06-24-2018, 08:34 AM
lr172 lr172 is offline
To add tothe previous guidance, Many rv builder put a diode directly on the starter solenoid. If you already have one properly installed there, you do mot need another at the switch.
Larry
Old 06-24-2018, 06:38 PM
Thanks for the info. Mine is hooked up to the start relay per the instructions that came with the switch. The directions just did not tell you what it does.
RV 7
Old 06-24-2018, 07:57 PM
Taltruda Taltruda is offline
Default Diode
https://youtu.be/bvDuyM2e4gw
Here?s an explanation
Tom
Las Vegas
RV-8 empenage almost finished
Horizontal Stab done! 2-15-2020
Vertical Stab Done! 5-27-2020
Rudder Done! 5-31-2020
Wings ordered!...
