Old 06-22-2018, 02:20 PM
RandyAB RandyAB is offline
Default Fibreglass primer
I'd appreciate suggestions for a good fibreglass primer. I've had a suggestion for SPI but it doesn't seem readily available in Canada. It has to be compatible with UV Smooth Prime.
______________________
Randy P.
1st time builder
RV10 - QB wings and fuse. Working on cabin top
St. Albert, Alberta, Canada
Reserved:C-GRPY
Old 06-22-2018, 02:56 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
I've been using the Kirker epoxy primer -
https://www.autobodytoolmart.com/kir...r-p-12620.aspx
I think they will ship to Canada - it looks like you may be closer to them than I am in Arizona.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 06-22-2018, 03:00 PM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is offline
Use the same primer you will use when painting the plane.
Carl
Old 06-22-2018, 03:42 PM
Carl
I'm going to have the plane professionally done (to be determined who exactly) so I don't know that info Carl.
Randy P.
1st time builder
Reserved:C-GRPY
Old 06-22-2018, 03:45 PM
Thank you Gil. I will look into this one.
Randy P.
1st time builder
Reserved:C-GRPY
Old 06-22-2018, 04:02 PM
https://www.napacanada.com/en/p/DSSHEPSG?ref=MA==
Does this look appropriate?
Randy P.
1st time builder
Reserved:C-GRPY
Old 06-22-2018, 05:33 PM
az_gila's Avatar
Post
I forgot to mention they do a white colour, which I think looks better if you want to test fly before final paint.
Gil Alexander
Old 06-22-2018, 07:17 PM
If you haven't picked a painter, just get the contours right, fill the pinholes, and wait until you pick your painter. Once you pick your painter, he may have a product line he wants you to use if you do any further prep work.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 06-22-2018, 08:48 PM
az_gila's Avatar
Smile
I tried that with a couple of local painters and they all said the same thing.
Use an epoxy primer if you want to fly it first.
They didn't seem to be fussy about a particular one.
Gil Alexander
