Old 06-22-2018, 10:42 AM
digidocs's Avatar
digidocs digidocs is offline
Question Bootstrap / Lowry flight testing---anyone tried it?
Hi VAF,
I'm curious if anyone has tried or has thoughts on the Bootstrap Performance Approach method described by John Lowry?
It seems like a simple way to get a good amount flight test and performance data for a RV.
If you're not familiar, there's an outline of the method described in these three articles, but I think having the book might also be important for getting some of details correct.
Bootstrap Method Part 1 - https://www.avweb.com/news/airman/182410-1.html
Bootstrap Method Part 2 - https://www.avweb.com/news/airman/182418-1.html
Bootstrap Method Part 3 - https://www.avweb.com/news/airman/182421-1.html
Book - Performance of Light Aircraft, John T. Lowry
Thanks for your thoughts!
Old 06-22-2018, 11:57 AM
Vac Vac is offline
Default Yes
Those are an excellent set of resources, and will produce good data that can be verified or refined using other flight test techniques described in AC 90-89B or other flight test resources. The procedures for fixed-pitch airplanes are very straightforward, and there was a very good article in KitPlanes describing the procedure applied to an airplane fitted with a constant speed prop.
Overall it’s a great place to start whether you are conducting Phase 1 or simply learning a “new to you” RV as a second or subsequent owner.
Vac
Mike Vaccaro
RV-4 2112
Niceville, Florida
