Roll bar
Looking at this weldmart closer, the problem is with the bending of the tubing. The bends are not parallel. The 90 degree angles on the feet are close to being correct but with incorrectly bent tubing, they are off more than I first guessed. With one weldmart on a flat surface, the weldment on the other end is almost 1/4 inch off. The tubing needs to be twisted to correct the fit and I don't think we should even attempt to twist the chromoly tubing.
