Old 06-21-2018, 10:27 AM
tmillican tmillican is offline
Default RV-xA towbar attach point question
I have an RV-8A. I didn't build it. I've never used (or needed) a towbar until now. I now have a tug in my hangar to use with the Baron, thus I have a towbar for which I can get adapters for the RV. (https://www.beechtalk.com/forums/vie...=unread#unread)
My RV, though, has the following on the nosegear attach point.
On the left side there is an AN bolt (about 3/4" head) and a stack of four flat washers (13/16" diameter).
On the right side there is a allen bolt and a stack of four smaller flat washers(all of which about 5/8" OD).
I can have a towbar adapter made to fit these two different sizes, but I'm thinking that my RV is non-standard (if there is any such thing). What kind of bolts do others have for nosegear attachment points? Should I just keep mine as is and get the towbar made to fit, or should I swap out my bolts and if so, for what kind of bolts?
Troy
Troy Millican
CFI
Columbus, TX (66R)
RV-8A, purchased flying
Cessna 150F; Beech Baron B55
Old 06-21-2018, 10:42 AM
Ralph Inkster Ralph Inkster is offline
I'm thinking that the original Allen bolt was stripped out sometime in it's past and the hole was drilled & re-threaded for the larger bolt. I guess you could look into tapping out the hole for a Helicoil for the proper Allen bolt thread if you want...
Ralph
built a few RVs, rebuilt a few more, hot rodded some, & maintained/updated a bunch more
Old 06-21-2018, 12:11 PM
John Tierney John Tierney is offline
Default Bogert
A common modification is these longer Bogert bolts/sleeves.
https://bogertaviation.com/collectio...va-tow-pin-kit
John Tierney
Vonore, TN
RV-7A - N777JT Flying
Old 06-21-2018, 02:00 PM
I have seen those Bogert tow pins referenced on another thread. Yet looking at the two pictures on their website I cannot tell to where they are intended to attach or how they are intended to function.
It may be possible that one of them would attach to my right side with the Allen bolt, but I would still need to modify the left side which has the AN bolt.
Troy Millican
CFI
Columbus, TX (66R)
Old 06-21-2018, 02:37 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Yep, same thought on this.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 07-16-2018, 05:04 PM
RV7A Flyer's Avatar
Look at DWG C1, area B7. Where it says "11/16 hole in U-813A for Allen screw"? Also referenced in area B-10, 3/8x24x3/4 Allen Screw, etc. That's the place where the Bogert pins go...in place of the Allen screw.
I have them, they work great (and are easy to remove thus allowing simple removal of the wheel pant when necessary).
2019 Dues paid!
