Old 03-18-2007, 05:00 PM
avi8tor50 avi8tor50 is offline
Default Current Limiter size
Just wondering what size current limiter most are using and how many are even using current limiters?
Also, how large a doubler plate are you using for a Commant 122?
Peter K
9a QB
Old 03-18-2007, 05:02 PM
hevansrv7a's Avatar
hevansrv7a hevansrv7a is offline
Default Comant doubler
Originally Posted by avi8tor50
J
Peter K
9a QB
Simply because the belly skin appeared to be .040, I used .040 for the doubler. Open to criticism, but it seemed reasonable at the time.
H. Evan's RV-7A N17HH 240+ hours
We can lift ourselves out of ignorance, we can find ourselves as creatures of excellence and intelligence and skill. We can be free! We can learn to fly!" -J.L. Seagull
Paid $25.00 "dues" net of PayPal cost for 2015, 2016, 2017 and 2018 (December).
This airplane is for sale: see website. my website
Old 03-18-2007, 07:20 PM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Default Current protection: Fuse or CB?
Also, how large a doubler plate are you using for a Commant 122? Peter K 9a QB
Ditto on 0.040 belly skin, 0.040 doubler. If you can pick up a floor rib (more correctly an intercostal) with a flange the better.
Current limiter? hummmmm drawing a blank? Limit what current? Are you talking Fuse or CB? There is no current limiter in the classic sense, but it does protect the wire from TOO much current.
In general if current gets to high for a cuircuit (ie ground or short) you protect the wire with a fuse or circuit breaker (CB) at the power source. With out it the wire would glow red, melt the insulation and be a fire hazard. The size of the wire must be large enough to handle the max operational current and also be more than the protection (fuse/CB). Most find the most they need is about 18-20 discrete fuses or CB's, but you can by with less if you GANG on each fuse, like in you house, where one CB handles many circuits.
Are you talking about OVER VOLTAGE?
If you are talking about over voltage (OV) protection that usually involves
something to do with the source it self, in our case the source is either battery or alternator. Since the battery is unlikely to go "over voltage" we are talking alternator. That is a hot topic. If you search OV or over-voltage you can read enough to have your eyes bleed.
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
2020 Dues Paid
Old 03-18-2007, 07:28 PM
Actually, I have seen several builders who use a current limiter between the alternator and the main bus. B&C sells them and my understanding is that Bob Nuckolls is leaning more to the current limiter than a large fuse between the alternator and the main bus. The current limiters that B&C sell come in several different amp strenghts. Was just wondering what others have used. You might want to check out his site.
Old 03-18-2007, 07:34 PM
Default OK I am stumped
Actually, I have seen several builders who use a current limiter between the alternator and the main bus. B&C sells them and my understanding is that Bob Nuckolls is leaning more to the current limiter than a large fuse between the alternator and the main bus. The current limiters that B&C sell come in several different amp strengths. Was just wondering what others have used. You might want to check out his site.
Have no idea, never heard of a Current Limiter between the alt and the buss, but than you answered you question, you need one?
I think you are talking about a big FUSE? That fuse is sized at or slightly above the max output potential of the alternator. So you have a 45 amp alternator, 50 or 60 amp fuse will work. Again current limiter? I think fuse.
If not, you are talking about a OV relay. I would not recommend that on ANY ND alternator. Van does not recommend or warranty alternators with OV relays, but again check the archives and search on OV or over voltage or overvoltage.
I know Bob Nuckolls swears by his OV relay, but it has been the death of many ND alternators. The fact is ND alternators are very reliable and DON'T go super nova OV like Bob scares people into thinking. The cure is worse than the ill. In fact an OV relay is heavy and adds more connections and chance for failure. Trust me or not, call Van. Bob N's answer is Van is ignorant and Bob. Of course Bob said that before he knew all the problems Van has seen with builders who follow his wiring, specifically the OV relay. Van also sells 10 alternators or more a month for a decade or more; do the math, they hear about all the problems and the common thread in many was Bobs OV relay and "crow bar".
My OV opinion is for most folks no additional OV protection is needed on the ND (NipponDenso) alternators with internal voltage regulation (I-VR). They are somewhat self protected or fail in a safe or benign way. There is the "Plane Power" brand of alternator, which is a modified ND with an extra OV module or protection device. It senses an OV and turns the alternator off automatically. The few people that have experienced OV, with a I-VR ND alternator have found it to be mild. Mild means target voltage should be 14.3-14.6 volts, and the voltage wonders up to 15 or 16 volts. In general you can manually turn the alternator off your self in that unlikely event. 16 volts should not damage modern avionics which are designed to work from 10-30 volts, and tolerate a 60 volt Spike. Of course you don't want to fly around for a long time with +15 volts as it will damage the battery. However as you know if you voltage is high you can usually get it down by lowering RPM and adding more load, like landing lights.
Good luck
George
Raleigh, NC Area
2020 Dues Paid
Old 03-18-2007, 07:56 PM
Just checked Bob's site again. Yes the current limiter is similar to a big fuse-just has a few different characteristics. He is recommending that it be substituted for the "big fuse" the he previously recommended betwee the b lead of the alterhnator and the starter contactor. And it is called a "current limiter." I will be using a Plane Power 60 amp alternator.
Anway, for those of you out there that see this discussion, the question stands: What size ANL current limiters are you using?
I was thinking about 70-80 amp if that size is available since Bob suggests one abouyt 20% above the alternator output.
Old 03-18-2007, 08:22 PM
az_gila's Avatar
az_gila az_gila is offline
Exclamation Standard values here
Well this TX Avionics place seems to follow Bob N's theories...
This link gives the ANL standard sizes...
http://www.dallasavionics.com/cgi-bi...ubcat=limiters
80 Amps would bethe closest to the one you want...
IIRC Home Depot (Aviation electrical section) also has them...
gil in Tucson
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 03-19-2007, 12:01 AM
Paul Eastham's Avatar
Paul Eastham Paul Eastham is offline
How do you or Van's know that these failures aren't just due to shoddy alternators rather than the regulator/OV?
In fact an OV relay is heavy...
A whopping 9 ounces according to their web site...?
Paul Eastham - Mountain View CA
RV-9A standard build, flying! ~300 hrs
EAA Chapter 338 San Jose
Old 03-19-2007, 06:15 AM
ABRV4 ABRV4 is offline
I believe the limiter I installed is 60 amps, but I'll have to check to make sure. This is for the 50 amp alternator and basic VFR panel in my RV-4.
Alan
Old 03-19-2007, 09:00 AM
Rick_A's Avatar
Rick_A Rick_A is offline
Default I put in an ANL 60
I don't even have the engine yet, but installed the ANL 60 from B&C. I plan on running the 60 Amp Plane Power Alternator from Vans. Now I'm wondering if the 60 is correct.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
