Go Back   VAF Forums > Model Specific > RV-9/9A
Old 06-18-2018, 10:09 PM
Flyer2017 Flyer2017 is offline
Default Rudder damage-repair or replace?
Last week, we were on our way from Logan, UT - KLGU to the AOPA Fly-in at KMSO and stopped overnight to visit a friend in Lewiston, ID - KLWS. The plane was parked and tied down with rudder, aileron and elevator locks in place when a big storm came thru overnight in the opposite direction of the usual prevailing wind (from the tail of the plane). The gust lock (a u-shaped wire) was turned into a pretzel and the wire severed at the rudder. The rudder suffered a hole on the left side from being driven against the elevator and a dent on the right from the same problem. The bottom six rivets in the trailing edge were ripped loose leaving the holes on the left larger than those on the right so it can't just be riveted back together. We patched it up enough to get back to KLGU but the question now is whether to repair the damage or just order a new rudder kit and replace the rudder? We didn't build the plane so building a rudder would be a first effort. It is flyable now with Gorilla tape over the hole and temporary bolts to hold the trailing edge together. Reskining seems like more work than building new. Advice??
RV-9A, 0-320, FP Prop, paid 2021
Cessna 140A 0-200
Old 06-19-2018, 04:41 AM
JohnInReno's Avatar
JohnInReno JohnInReno is offline
Default Buy
I had a similar incident and I was able to find an acceptable rudder already built. There are more tail kits than airplanes.
On the other hand, building the rudder is fairly easy if you have the hand tools and would be educational.
John Morgensen
RV-9A N946PM 600+ hours since 2013
Nevada/Arizona
Old 06-19-2018, 08:40 AM
airguy's Avatar
airguy airguy is offline
The rudder is the easiest, and cheapest, component on the airplane to build. It's also the first component built in the kit for a reason - it's relatively forgiving of mistakes, fairly easy to build, and cheap to replace if you completely hose it up. For a first-time building experience you would be hard-pressed to pick a better component than the rudder.
Garden City, TX VAF 2021 dues paid
N16GN flying 900 hrs and counting; IO360, SDS, WWRV200, Dynon HDX, IFD440, G5
Old 06-19-2018, 08:46 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Please check carefully for other damage, impact point on the elevators, and rudder hinge mounting points come to mind.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 06-19-2018, 10:35 AM
It is only a month to AirVenture. I'm all for buying a built rudder or building a new one if I can do it by then. I'm at KLGU in Logan Utah and would love to find someone that could give some guidance who lives nearby. I talked to Vans and they said that temporarily patching the dents/holes and putting doublers and new rivets on the trailing edge would probably get me flying but a new rudder would obviously be better. There is no "kit" so I'm making a list of parts from the drawing. Anyone know of a rudder already built that is for sale? Thanks
Cessna 140A 0-200
Old 06-19-2018, 02:29 PM
airguy's Avatar
If you can wait until Airventure, show up with some cash and you can probably fly home with a new rudder. Odds are good someone will have one. And if not, place your parts order with Vans on location before you leave.
Old 06-19-2018, 05:34 PM
crabandy crabandy is offline
I have an assembled rudder I would sell, pm sent.
RV 7 500 hours and counting
20 donation done
Old 06-19-2018, 06:22 PM
WAustin WAustin is offline
Default Same damage
I had the same damage to my RV7A rudder in Australia. Even including freight building a new rudder was the easiest and cheapest way to fix it. Not only was the damage to the skin, but the rudder was twisted. I didn't see the damage on a preflight, don't know how I missed that when I did see it, and the plane had a strong yaw. Usually use right rudder for takeoff, but this was insane..... needed full right rudder just to stay straight.
Replaced rudder with a new one, took a weekend to build and a weekend to paint to match. As the original was the first thing I built, and now the new rudder is the last thing built, the build quality is much better. I no longer need a wedge to keep the ball in the centre.
All the advice I got here from the local tech councillors was just rebuild, it'll be quicker and better overall. I have to agree.
Old 06-19-2018, 06:32 PM
Walt's Avatar
Walt Walt is offline
And then prevent it from happening again with one of these:
http://www.aircraftspruce.com/catalo...rs05-11899.php
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags
Old 06-19-2018, 09:16 PM
airguy's Avatar
or one of these
http://www.aircraftspruce.com/catalo...hp?recfer=9811
