Old 06-23-2018, 06:13 PM
RViter RViter is offline
Originally Posted by Mark C. View Post
Have any of you guys make a mounting bracket for the 472 as it uses screw location from the 470? Dynon said I would get a call early Fall for mine.
Thanks, Mark C. IL
Mark: when did you request the '-472 upgrade from the -470'? (sounds like it was way later than the original announcements before OSH2017.
Most of the comments about 'got the call' seem to be very vague as to whether they are going -470 to -472, or -472 to updated -472, or some other configuration. It's difficult to even speculate whether Dynon is actually catching up with demand or still swamped by success.
THANKS
gary
RV-6A QB Tip-Up, 1st Flight 3/18/17
O-360-J2A (modified & F/I), Sensenich FP (cruise)
VP-X Sport, Dynon SkyView, VFR day
(FFZ) Mesa, AZ - N234GB -
www.mykitlog.com/garyc
Old 06-23-2018, 06:57 PM
MercFE MercFE is offline
These are updates from 472 to 472...
Old 08-12-2018, 03:17 PM
Caummisar's Avatar
Caummisar Caummisar is offline
Default Dynon ADSB 470 to 472
Thanks, Mark C. IL
Here is the SV-ADSB-472 specification sheet:
http://www.dynonavionics.com/downloa...V-ADSB-472.PDF
It shows the mounting hole measurements and the change in antenna plug/dSub connector locations. Print it out at 100% and it can be used as a mounting hole template.
VAF# 835
RV-7A /FWF/Engine Re-Mounted/Big cut soon
Slow build --- ALL THE WAY
Victim of SB-632-B
2021 Dues Happily Paid
Old 08-12-2018, 03:58 PM
Jesse's Avatar
Jesse Jesse is offline
Thanks, Mark C. IL
I could draw it up an buz it out on the CBC if you need.
Jesse Saint
