06-17-2018, 11:03 AM
Low manifold pressure on takeoff?
I just did a takeoff where the engine only made about 15 inches MAP at full throttle, mixture full rich, 950 ft pressure altitude. The engine sounded the same, felt like it was making full power, and takeoff distance was normal. Fuel flow on takeoff was redlined, as expected.
The MAP slowly crept up to 20 inches while flying close to the airport at 3,000 MSL, full throttle. It never went above 20 inches though.
I tried unsuccessfully to Google this, search John Deakin's old articles, reading through my "Fly the Engine" book, etc. and am not finding anything. It seems the main discussion in other threads and articles is instead on high MAP. Does anyone have an idea what might be causing my low MAP on takeoff? I think I've ruled out a bad MAP sensor as I'm getting normal indications on the ground with the engine stopped.
Karl, Goodyear, Arizona (KGYR) ATP, CFII
RV-14A, Flying
Extra 330LX, Flying
RV-8, Sold
RV-7, Sold
Bearhawk 4-Place, Sold
=VAF= donor 2020
06-17-2018, 12:55 PM
Super Moderator
Clean the line
Have you ever cleaned the line between the sensor and the cylinder? They can get clogged over time. I clean mine out every year.
Vic
 Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
06-17-2018, 01:00 PM
Vic
+1
You would notice a difference in power and fuel flow if your were actually pulling that much vacuum compared to WOT and 29"
Larry
06-17-2018, 03:46 PM
Vic
Thanks Vic. I'll go take a look at it. What do you use to clean out the line? I would probably use 100LL unless there's a more elegant solution.
RV-14A, Flying
Extra 330LX, Flying
RV-8, Sold
RV-7, Sold
=VAF= donor 2020
06-17-2018, 04:12 PM
Super Moderator
Solvent
I use Brake Clean or any other solvent.
Vic
 Vic Syracuse
06-17-2018, 04:14 PM
I just went through this myself, and the guys above are correct. My MP gauge eventually stopped altogether. Pull the fitting at your engine connection first. Mine was packed with black gunk that was as hard as concrete. I used 0.035 safety wire and a good soak in MEK. An ultrasonic cleaner might accelerate this process.
06-17-2018, 04:16 PM
Your symptoms indicate black goo in the hose/line. 100LL works just fine.
Bill
RV-7
Lord Kelvin:
06-17-2018, 04:33 PM
Thanks everyone! I really appreciate it.
RV-14A, Flying
Extra 330LX, Flying
RV-8, Sold
RV-7, Sold
=VAF= donor 2020
