Old 03-18-2007, 09:21 AM
mikehoover's Avatar
mikehoover mikehoover is offline
Default Means of hoisting fuse to install main gear legs
Any suggestions for good/safe ways to lift the fuse to get the main gear legs installed? I have a 2-ton engine hoist, but wanted to see what other builders have done. Thanks!
Mike Hoover
Columbia, SC
www.aclog.com/rv-9a/
www.eaa242.org/
N194MH first flight on 08-26-12
Old 03-18-2007, 09:24 AM
frankh's Avatar
frankh frankh is offline
Default YUp
Strap around the engine mount top tube.
THis is how I did the wheelpant alignment
Frank 7a
Old 03-18-2007, 10:40 AM
scard's Avatar
scard scard is offline
Engine hoist with an eye hook and backer plate in the spar box.
http://rv9a.card-net.org/archives/20...6/on-the-gear/
Scott Card
CMW E-Lift
Old 03-18-2007, 01:17 PM
Radomir's Avatar
Radomir Radomir is offline
I used two RV builders (engine mount was in place).
Radomir
RV-7A sold
Old 03-18-2007, 02:28 PM
szicree szicree is offline
I put some of the wing bolts in, along with the steel splice plates. Then I took a long piece of gas pipe and stuck it through the spar box. Had a friend grab one side and I grabbed the other and we just put it on some tall jackstands.
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 03-18-2007, 02:35 PM
N941WR's Avatar
N941WR N941WR is offline
Mike,
Are you building a -9 or a -9A?
For my -9, I used an engine hoist.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
