Installing Governer Studs
All,
I have been trying to install the studs provided loose by my engine supplier for my propellor govenor. One end of the stud threads onto the supplied nuts easily, and also threads into the govenor pad quite easily.
The other end of the stud will not thread into the nuts and is very difficult to turn in the pad. I have installed a couple of the supplied nuts onto the stud in order to use a spanner to try to thread them in, but the studs will not go further, and they are not installed sufficently into the pad.
I do not want to force things... or break the studs/pad. Has anyone else had an experiece like this? I am wondering if the supplied stud has a metric thread on it or similar and/or if I am using the correct studs/hardware?
My engine supplier says the studs are not meant to go in easily but I suspect something is wrong here.
Thanks/Regards
Richard
