Control arm priming inside tubes
Hi all,
I received my emp recently, and i note that the powder coated elevator horns seem to be unpainted on the inside of the tubes.
Do i need to swirl some primer in them before they start to rust?
The tailwheel spring bracket is the same, however i assume i should not put any paint in there as i may have issues fitting the spring later?
Thanks for any advice.
