  #11
Old 06-10-2018, 08:16 AM
Mark33's Avatar
Mark33 Mark33 is offline
Default Honeywell 2TL1-10
It sounds like you need a Honeywell 2TL1-10. This is a two pole three position switch (on/on/on). Just wire in the middle and top positions and it?ll act just like an (off/on/on) switch. Like others have said though, I think you should have the ability to turn your lights completely off and not just have them come on with your master switch. I have mine wired up with two switches using the switch mentioned above along with a separate wig-wag (on/off) switch. It?s wired as such that the wig-wag function is really the master controller. What I mean by that is that regardless as to the position of the main light switch, if the wig-wag switch is on, the lights will be wig-wagging.
Mark
Old 06-14-2018, 08:34 AM
JimWoo50 JimWoo50 is offline
Default Thanks
Lots of good advice. Have reconsidered leaving the lights on full time even though they are very small .9? diameter led. Now I?m planning on-off-on: taxi lights and wig wag or strobe.
Jim Woolard C56
N9855J RV-6 Donated 2020
