  #11
Old 06-08-2018, 09:13 AM
Cdenora Cdenora is offline
Originally Posted by MrSparkle View Post
Try Pippen-York at Fredericksburg; http://pippen-york.com
They just quoted me $125 and said the paperwork takes longer than the test, about 30 minutes max. They were recommended by several RV guys here in San Antonio.
Ian Heritch (8T8)
RV12, N417E, Red Venom 2
Thanks Will do that
regards
christian
Old 06-08-2018, 09:34 AM
Walt's Avatar
Walt Walt is offline
Just to clarify things a bit: on a first time check the shop needs to verify "altitude data correspondence" with the altimeter, on most glass that uses serial data from the PFD thats pretty easy, if you have a gray code hook up use or a seperate altitude encoder than that means running both the encoder and altimeter thru the full range of altitudes and verify they match within 125'.
So it depends on what you have as to the cost of a first time check.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 06-08-2018, 10:18 AM
Piper J3's Avatar
Piper J3 Piper J3 is offline
Also, shop has to pull transponder and/or EFIS to get serial number of units for logbook entry and for the avionics shop records...
Jim Stricker
EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 622
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father & CFI) - USAAF 1st Lt. Captain B-17H
Old 06-08-2018, 02:24 PM
Yes this will be the first time check so they will have to open up avionics compartment ? of should I provide transponder numbers from records ?
Old 06-08-2018, 04:56 PM
Walt's Avatar
Make the job easier by providing Xpdr and ADAHRS SN's.
Old 06-09-2018, 05:03 AM
tomkk's Avatar
tomkk tomkk is offline
I just gave him my SN's, did not need to open avionics bay ...
Tom
Port Orange, Fl
EAA #51411
RV-12 N121TK ELSA #120845; first flight 06/10/2015; 700 hrs as of 02/2020
RV-12 N918EN ELSA #120995 Eagles Nest Project; first flight 05/18/2019
SPA Panther N26TK; First Flight 03/13/2020
