Go Back   VAF Forums > Avionics / Interiors / Fiberglass > ADS-B
Old 06-07-2018, 09:32 AM
BruceMe's Avatar
BruceMe BruceMe is offline
Default Transponder Check off aircraft
I have a G3X with the GSU 25 air data feeding my remote GTX-335R.
My aircraft/transponder have to be inspected for phase 1 compliance, can I do this off the aircraft if I pull those units?
-Bruce
Bruce Meacham
Building RV-4A 18ZM
Built/Own RV-4 254MM
First RV RV-3 3456B
VAF annual donation on autopay
Old 06-07-2018, 09:38 AM
BruceMe's Avatar
Default mobile check?
Is there a field transponder check capability? This is VFR, btw.
Bruce Meacham
Building RV-4A 18ZM
First RV RV-3 3456B
Old 06-07-2018, 09:52 AM
Needs to be installed, on the aircraft. A lot of the issues are coax, encoder/altitude, antenna, etc. There are many tech’s with portable equipment, they’ll come to you.
Old 06-07-2018, 01:16 PM
BruceMe's Avatar
Originally Posted by BobTurner View Post
Needs to be installed, on the aircraft. A lot of the issues are coax, encoder/altitude, antenna, etc. There are many tech?s with portable equipment, they?ll come to you.
I called all the avionics shops in town, nobody is portable. How would I find a portable transponder checker in Kansas City metro?
Bruce Meacham
Building RV-4A 18ZM
First RV RV-3 3456B
Old 06-07-2018, 01:20 PM
Raymo's Avatar
Raymo Raymo is offline
I don't see how they can't be portable. They have to take the test equipment to the airplane to run the tests.
Also consider turning the XPNDR off and flying it to the nearest shop within your P1 area for the test to be done.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 06-07-2018, 01:27 PM
And placard it as ?inop?. Unless you?re located within a transponder-required airspace (class B, C, 30 mile mode C veil). Your DAR should be okay with this.
Old 06-07-2018, 01:41 PM
BruceMe's Avatar
inside
Bruce Meacham
Building RV-4A 18ZM
First RV RV-3 3456B
Old 06-07-2018, 01:46 PM
Mel's Avatar
Mel Mel is offline
Originally Posted by BruceMe View Post
inside
Often you can get a waiver for one flight to a facility by calling the controlling facility.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 06-07-2018, 07:20 PM
+1
My home field (KLVK) is one mile inside the mode C veil around SFO. Not only will they give you a mode C waiver on request; if you go up to the tower and sign a waiver form, you can make it permanent.
Old 06-08-2018, 12:08 PM
BruceMe's Avatar
I'm exploring that... my FSDO inspector wants to inspect my transponder before flight.
Bruce Meacham
Building RV-4A 18ZM
First RV RV-3 3456B
