Old 03-16-2007, 08:18 PM
mbetti mbetti is offline
Default Bendix KY97A
I installed a KY97A in my panel. It works well except I have no side tone. This is a feature of the radio, so is there some way to adjust it? Could it be maybe turned off? Is it front panel controlled?
Appreaciate any help.
Mike
Old 03-16-2007, 09:51 PM
fmarino1976 fmarino1976 is offline
Default Check Mic lines
from the audio panel or to the radio, or from jacks to radio if you don't have an audio panel. If you don't have sidetone, chances are there is no voice been transmitted out either. If you can verify that there is voice out (listening on a handheld), there are some pots on the top or botton of radio (can't remember exacltly) One of them is labeled s/t, try adjusting that one. You are going to have to pull the radio out, adjust and try again until you find a comfortable level. Hope this helps.
A&P, IA, Avionics Tech, and finally: Pilot! (12/28/06)
Dying to build an RV10. Not quite ready yet
Old 03-17-2007, 02:55 PM
Found radio side tone adjusted too low. Counterclockwise to make louder and this took care of issue.
Mike Betti
