  #11
Old 06-07-2018, 02:56 PM
DonFromTX's Avatar
DonFromTX DonFromTX is offline
I have, often on auto and tractor engines. The open valve face tends to pick up some oxidation, which allows for some leakage. I have never pulled a Rotax head but would suspect the same there. Try running a compression check on a Lycoming that has sat for a time, same effect. Compression comes up after even a short run.
Originally Posted by EXflyer View Post
Why would the valves not seat? Have never seen that on any auto engines that I have worked on.
A&P, PP-SEL, Pathological Flier, EAA Technical Counselor
EAA Chapter 595 President,http://www.595.eaachapter.org/index.htm
Retired US Army Officer
Old 06-07-2018, 03:00 PM
DonFromTX's Avatar
You might be right there, had not thought about it much actually.
Originally Posted by Piper J3 View Post
I think the reference was to lifter bodies pumping up with air if oil not purged correctly. You'd have to draw air into oil pump/pressure galleries.
Old 06-11-2018, 12:37 PM
rv7boy's Avatar
rv7boy rv7boy is offline
Forum Peruser
Jim, and others, you might be interested in reading this article on the Rainbow Aviation web site.
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
